[Mapbender-dev] curl connector and proxy settings
Michael Schulz
mschulz at webgis.de
Fri Jan 26 09:16:44 EST 2007
does anyone think it will make sense to add a no_proxy parameter to
the proxy settings of the curl connection? I seem to have this issue
with every installation, mapbender in an intranet with a proxy, that
access intranet (therefore the no_proxy setting) and internet wms
servers.
How are the you dealing with this problem (or maybe it's no problem at
all). The systems env settings of http_proxy an no_proxy seem to get
ignored by apache/curl.
The patch would include a new parameter for the curl connection in
mapbender.conf and and slightly changed class_connector.php
Cheers, Michael
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev
