[Mapbender-dev] Test of RC1 / some thoughts
Uli Rothstein (WhereGroup)
uli.rothstein at wheregroup.com
Tue Jan 30 04:11:29 EST 2007
dear list-members,
Marc Jansen schrieb:
> Hey Marko, hey List,
>> 2. Test of upgrading a 2.4 version
>> - everything seems to work fine, too. (The first time I did the
>> upgrade, I had all entries of gui_layers twice. Don't know, what I did
>> wrong. Whatever, the second time everything worked pretty nice. )
>> Idea:
>> I saw, that you set "default_with_oids = true" in the new pgsql
>> schema, but wouldn't there be a chance for grouped primary-keys for
>> all the pk-less tables, for example the table gui_layer with a
>> grouped-pk of fkey_gui_id and fkey_layer_id to prevent double entries.
>> (same idea for all other tables without PK like
>> gui_layer,gui_wfs,gui_wms,...)
> I second that, if there are no other relevant issues. I can not see any
> -- do you? A grouped PK should be the right way to handle theses tables.
>> Or is there a reason, why there are no PKs at some tables? In my
>> opinion, there is no logic of having two entries, for example with the
>> same fkey_gui_id and fkey_layer_id in table gui_layer.
> Yipp, speaking from a database view of things, one does not need two
> entries with the same values in the field you named. Am I missing
> something?
I don't now. There may be some technical reasons to publish a layer twice,
because nonexisting transparency of services for example. So you have more
flexibility for the arrangement of layers. (But I've never seen such
constructions in reality...)
best regards
Uli
> Good thoughts, Marko!
> -- Marc
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Ulrich Rothstein
WhereGroup GmbH & Co.KG
Siemensstraße 8
53121 Bonn
GERMANY
uli at osgeo.org
www.wheregroup.com
www.mapbender.org
Zentrale: ++49 (0) 228 909038 0
Durchwahl: ++49 (0) 228 909038 17
Fax: ++49 (0) 228 909038 11
ACHTUNG: Die Firmen Geo-Consortium, CCGIS und KARTA.GO haben ihre Fusion als
WhereGroup zum 1.1.2007 bekannt gegeben.
Daher ändern sich ab Januar 2007 die Email Adressen und Telefonnummern.
More information about the Mapbender_dev
