[Mapbender-dev] Trac Spam
Arnulf Christl (OSGeo) arnulf.christl at wheregroup.com
Sat Jul 21 06:48:31 EDT 2007
On Fri, July 6, 2007 16:49, Frank Warmerdam wrote:
> Folks,
> The Trac Spammers have found our Trac instances and are actively spamming
> those that allow anonymous ticket creation and modification.  For example
> this recent spam on the Mapbender trac instance:
> Changes (by anonymous):
>   * cc: mapbender_dev at lists.osgeo.org (removed)
>   * cc: None (added)
>    * component:  core => print
>    * summary:  Titled GUIs (new zebra) => None
>    * version:  2.4.1 => 2.1
>    * milestone:  => Support usage of Styled Layer Descriptors (SLD)
>    * keywords:  login, gui list => None
> Comment:
>   #!html
>   <u style="display:none"><a href=http://search-
>   painter.bravehost.com/map.html>Painter</a> <a href=http://the-interior-
>   design.bravehost.com/map.html>Interior design</a></u>
> Beyond the fact that our google karma is being redirected to serve
> nefarious ends, there is also random damage being done to legitimate
> trac tickets.
> For the time being I have disabled anonymous ticket creation and
> modification.  Anyone wanting to submit or modify a ticket will now
> need to login with an OSGeo userid.  If this is contrary to the wishes
> of the Mapbender PSC I (or Astrid or Christoph) can revert this change.
> Best regards,
This is probably the best solution, thank you for making these changes. We
will launch some information to this regard to the Mapbender users.
Bets regards,
Arnulf Benno Christl
http://www.osgeo.org
(OSGeo Board Member)
+50.7342N   +7.0707E
More information about the Mapbender_dev mailing list
