[Mapbender-dev] Mapbender work group I18N
Marc Jansen
jansen.marc at gmx.de
Wed Jul 25 07:58:45 EDT 2007
for the generated output on a breezy badger ubuntu see the attached file.
-- Marc
Christoph Baudson schrieb:
> Hi,
> See http://www.mapbender.org/index.php/Internationalisation
> we would like to internationalize Mapbender. We would need some feedback
> on how different platforms behave with the setlocale function. Could you
> please run the attached script and send the generated file
> (locales-logfile.txt) back to the list and tell us on which platform it
> run.
> We would appreciate if you could run the test as soon as possible.
> Thanks
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
uname: Linux h1051964 2.6.8-3-686 #1 Tue Dec 5 21:26:38 UTC 2006 i686
$_SERVER['OS']: not set
identified as: linux
Locale it_IT.utf8 not found
locale de_DE.utf8 ok on linux
locale en_US.utf8 ok on linux
More information about the Mapbender_dev
