[Mapbender-dev] Cleaning up the SQL database
Samson, Marko
Marko.Samson at wald-und-holz.nrw.de
Mon Jun 4 07:39:11 EDT 2007
> -----Original Message-----
> From: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of
> Arnulf Christl
> Sent: Thursday, May 31, 2007 1:50 PM
> To: Discussion of Mapbender Development
> Subject: [Mapbender-dev] Cleaning up the SQL database
> Hi,
> I propose to change our way to manage SQL data in Mapbender.
> There are two different kinds
> * Service data (WMS, WFS)
> * GUI element data (code, module, position, content, element
> variables, etc.)
> == Service Data ==
> This is a hot topic when updating. Currently we have a fixed
> ID that is generated by the development server's sequence.
> This is horror for people who maintain a large number of WMS
> and have them organized in GUI. Currently every time
> Mapbender is updated we get load-errors because of
> constraints on the WMS ID or - even worse - we mess up the
> client's repository and bound GUIs.
Why don't we reduce the 'basic' services to 'Demis World Map', 'Jpl
World Map', 'Germany' and 'MB Users' (for example) and just offer a list
of other services-links at the wiki. So everyone can add services and
delete obsoleted links. These basic-services could be offerd with a
'Basic Services' insertscript, for people who need a basic installation
for testing mapbender or whatever.
That would simplify to handle a effective list of services and updating
the database, too.
> == GUI element data ==
> GUI element data comes in two variants:
> # template GUI (currently gui, gui1, etc.) # as an "SQL
> template" to be used to update private GUI.
> In the second case it is required to add the GUI name to any
> update scripts. Potentially we do not need to do this because
> people can first update gui and gui1 and then copy from those
> GUIs. (There was a separate discussion to rename gui and gui1
> into template_gui or template_basic_gui, etc.)
> Some Mapbender functionality needs several modules. Therefore
> sometimes in the Wiki we name the function as the code,
> sometimes we invent a new name. Example:
> * http://www.mapbender.org/index.php/AddWMS (simple)
> * http://www.mapbender.org/index.php/MonitorCapabilities (many)
> Another background is maintainability of the SQL. Currently
> keeping the dump up to date is painful and error prone. My
> hope is that if we split the large SQL chunk up into little
> pieces it will help maintenance because then the developer of
> the corresponding module also maintains the SQL snippet. The
> snippets are stored using the SVN which will also enhance
> updating for professional users and will allow us to have
> regular auto-builds over night so that the dev server is
> always up to date.
I like the method of copying from one 'basic_gui'.
/*now brainstormingmode*/
On the other hand, it would be nice to have a little function to insert
a new module/element into a specified gui.
If we have splitted SQL for every element, we could create a
mod_insertelementintodesiredgui script much easier.
Perhaps it would be possible to create it with help of the sql-snippets
and auto-builds from svn, to have a generated xml file, or something
like that, with all single element-sqls ordered by the element names.
(something like:
<element name='logout'>
<module_name>mod_logout</module_name>
<functionality>Ends this session.</functionality>
<insertsql>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public,
e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width,
e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
e_mb_mod, e_target, e_requires) VALUES($Request['desiredgui'], 'logout',
'2', '1', 'Logout', 'img', '../img/button_gray/logout_off.png',
'onClick="window.location.href=''../php/mod_logout.php?sessionID''"
border=''0''
onmouseover=''this.src="../img/button_gray/logout_over.png"''
onmouseout=''this.src="../img/button_gray/logout_off.png"''
title="Logout"', '660', '10', '24', '24', '1', '', '', '', '', '', '',
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
var_value, context, var_type) VALUES($Request['desiredgui'], 'logout',
'logout_location', '', 'webside to show after logout' ,'php_var');
</insertsql>
<dependencies></dependencies>
</element>
<element name='nextone'>
So the script could parse the generated-file and offer the elements at
the new installation-form, where the user just has to select the desired
element and to insert his desired gui.
Would this (builing a file(xml for example) from svn-sqlsnippets) even
possible with auto-build svn functionality? I don't know!
So far, enough storm across my brain now.;-)
What do you think about it?
Sadly, I can't join you today at IRC-Meeting!
cu,
Marko
> This needs a lot more thought as it will even tie back into
> packaging, install scripts, etc. Potentially this is better
> done in the Wiki once we know what we are talking about. Feel
> free to start this as a new page or tie it to a Trac ticket.
> Regards, Arnulf.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
