[Mapbender-dev] separated map.js and map.php
Michael Schulz mschulz at webgis.de
Tue Jun 5 10:55:16 EDT 2007
Hi Uli,
thanks. map.js is there (even with the sld changes ..., great), only
it seems map.php is not updated in the sld branch. Could you update
this one also?
THX, Michael
2007/6/5, Uli Rothstein (WhereGroup) <uli.rothstein at wheregroup.com>:
> Hi Michael,
> the js parts from map.php are merged with the map.js and all files are committed.
> Please check the sld-branch, whether anything works fine for you.
> best regrads
> Uli
> Ulrich Rothstein
> WhereGroup GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - 17
> Fax: +49 (0)228 / 90 90 38 - 11
> mailto:uli.rothstein at wheregroup.com
> http://www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
