[Mapbender-dev] new version available - Mapbender 2.4.2 rc1
Samson, Marko
Marko.Samson at wald-und-holz.nrw.de
Wed Jun 6 04:52:30 EDT 2007
Hi Michael,
concerning to resize_mapsize:
does the javascript error occur at startup or while you digitize something or whatever? I installed rc1 and copied resize_mapsize from gui2 to gui_digitize and changed it to auto. But I don't get an error at firefox/firebug.
What have you done to get this error?
My Sys:
mb2.4.2._rc1 (new_installation)
php 5.2.2
Firefox 2.0.0.4 & IE6.0.29
Gruß,
Marko Samson
Marko Samson
Landesbetrieb Wald und Holz NRW
GIS-Anwendungsentwicklung
Referat I-5
Albrecht-Thaer-Straße 34
48147 Münster
Tel.: 0251/91797 - 169
Mail: marko.samson at wald-und-holz.nrw.de
> -----Original Message-----
> From: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of
> Michael Schulz
> Sent: Tuesday, June 05, 2007 6:29 PM
> To: Mapbender Developer List
> Subject: Re: [Mapbender-dev] new version available -
> Mapbender 2.4.2 rc1
> Hi,
> i have just setup the following test:
> - mapbender 2.4.2 rc 1, new installation
> - php 5.1.2
> - postgres 8.1.4 / postgis 1.1.5
> - utf-8
> so far (first few tests ...):
> - installation without problems
> - i get a javascript error when adding the resizeMapsize
> module (with auto option) to the gui "gui_digitize". I have
> observed this error also in older svn checkouts, but wasn't
> sure if it was due to special changes on my side. Can someone
> confirm this? The error:
> map.php, line 56: highlight has no properties:
> for(var
> i=0;i<mb_MapRequestSubFunctions.length;i++){eval(mb_MapRequest
> SubFunctions[i]);}}
> - one tiny remark: never used meetingPoint before, so I
> tested that in gui "gui": the generated link has a bbox set,
> but since the setbbox module is not enabled by default in
> this gui, it has no effect (reproduced on the demo). Maybe
> this dependency should also be documented on the module wiki
> page (http://www.mapbender.org/index.php/MeetingPoint).
> ok, more testing in the coming days.
> BTW. Do you have a special plan on what should especially be tested?
> Cheers, Michael
> Michael Schulz
> mschulz at webgis.de
> in medias res
> Gesellschaft für Informationstechnologie mbH
> In den Weihermatten 66
> 79108 Freiburg
> Tel +49 (0)761 556959-5
> Fax +49 (0)761 556959-6
> http://www.webgis.de / http://www.zopecms.de
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
