[Mapbender-dev] double entries in layer_style & layer_epsg in
2.4.2rc1 dump, primary keys, svn
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Mon Jun 11 09:56:52 EDT 2007
As far as layer_epsg is concerned, I had written an SQL to solve that
problem, see
http://www.mapbender.org/index.php/Database_Changes_2.4.1#layer_epsg
Strange that it didn't make it in 2.4.1 already
Christoph
Samson, Marko schrieb:
> Hi devs,
> I try to create a new up-to-date database diagramm with dbdesigner4 at the moment. In the process I realised, that the tables layer_style and layer_epsg have no primary-key and have some double entries(dump from 2.4.2rc1 for postgres-utf8).
> Is there a reason for double entries and missing pks? (or did we forget the pks for those tables, last time we had the discusson about pks?)
> select fkey_layer_id, name, count(*) from layer_style group by fkey_layer_id, name having count(*) >1
> select fkey_layer_id, epsg, count(*) from layer_epsg group by fkey_layer_id, epsg having count(*) >1
> What about primary keys:
> pk_layer_style (fkey_layer_id, name)
> pk_layer_epsg (fkey_layer_id,epsg)
> Btw.
> Perhaps it would be possible to save this or another diagramm at the svn to have an up-to-date diagramm at every time? But we should have an agreement for a standard db-tool or a file-format. (dbdesigner can export to mdb-xml, sql and his own xml-format)
> What do you think?
> Greetings,
> Marko Samson
> Marko Samson
> Landesbetrieb Wald und Holz NRW
> GIS-Anwendungsentwicklung
> Referat I-5
> Albrecht-Thaer-Straße 34
> 48147 Münster
> Tel.: 0251/91797 - 169
> Mail: marko.samson at wald-und-holz.nrw.de
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Baudson Christoph
http://www.wheregroup.com
More information about the Mapbender_dev
