[Mapbender-dev] [Fwd: FW: [SAC] Subversion vhost
migration underway]
Arnulf Christl
arnulf.christl at wheregroup.com
Mon Mar 5 11:59:41 EST 2007
Frank Warmerdam wrote:
> Christoph Baudson (WhereGroup) wrote:
>> the old svn URL is no longer working; try the new one
>> https://mapbender.osgeo.org/mapbender
> Christoph,
> Aii - no!
> It should be https://svn.osgeo.org/mapbender
Hey Christoph,
please let us know when you have committed the changes so that we can go back to normal operation. I guess this makes you take on the Operation Administrator role. Congratulations and thank you.
Best regards,
Arnulf.
> In fact, what you have quoted will work due to the wildcard dns thingy
> being re-enabled temporarily but it will break immediately after that.
> Paraphrasing from my announcement to gdal-dev:
> Howard has made the changes to Mapbender's subversion and for somewhat
> esoteric
> reasons, the old subversion url no longer works. So a small change should
> be made in your root mapbender directory if you want an existing tree to
> continue
> to work.
> Do:
> svn info
> And look for the URL line. Something like:
> URL: https://svn.osgeo.org/svn/mapbender/trunk/mapbender
> If this line has https: then do the following in the same directory:
> svn switch --relocate https://svn.osgeo.org/svn/mapbender \
> If the URL line is using http: then do this:
> svn switch --relocate http://svn.osgeo.org/svn/mapbender \
> http://svn.osgeo.org/mapbender
> By the way, I'd strongly discourage using http: for anyone doing commits.
> Please only use http: for anonymous checkouts, and use https for any
> tree where you plan to make changes back to the master.
> PS. if you have something like https://mapbender.osgeo.org/mapbender then
> also switch that. eg.
> svn switch --relocate https://mapbender.osgeo.org/mapbender \
More information about the Mapbender_dev
