[Mapbender-dev] workgroup GDE: treeGDE2 - multilanguage for the contextmenue
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Tue May 8 03:22:08 EDT 2007
Hello devs,
there is a request for multilanguage in the new treeGDE2. The text in
the context menu (Move up, Move down, Hide...)  should be configurable.
At the moment the text is set in the mod_treefolder2.php
How can we solve it:
- element vars for every entry? - that would mean another 8 element vars
- treeGDE2.conf-file: file where the textes can be defined, only one
element var to include the conf-file (similar to the solution of the
element digitize - see element var: digitize_conf_filename)
What do you think?
Greetings astrid
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 http://www.wheregroup.com
 Amtsgericht Bonn, HRA 6788
 Komplementärin:
 WhereGroup Verwaltungs GmbH
 vertreten durch:
 Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
