[Mapbender-dev] synchronisation / register functions
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Mon May 21 06:36:55 EDT 2007
To synchronise the modules loaded in a GUI, map.php offers register
functions like
function mb_registerInitFunctions(stringFunction){
mb_InitFunctions[mb_InitFunctions.length] = stringFunction;
A function registers itself via
mb_registerInitFunctions('tab_init()');
These functions will be executed at certain events, for example onload
function init(){
for(var i=0; i<mb_InitFunctions.length; i++){
eval(mb_InitFunctions[i]);
A problem with this design is, that a string is evaluated. So when you
include function parameters in the string, the scope of the passed
variables is dependent on where the eval takes place. Imagine two
functions (with parameters) from different modules register at the same
event...where shall the evaluation take place?
The approach is not modular. What would be nice to have? A redesign
might not be necessary, but desirable for the future. Maybe we can do
some brainstorming.
I came up with this, but its drawback is, that you can't pass any
parameters (so it's kind of pointless).
var FunctionArray = function() {
this.list = [];
this.register = function (aFunction) {
this.add(aFunction);
this.execute = function () {
for (var i = 0; i < this.count(); i++) {
var aFunction = this.get(i);
if (typeof(aFunction) == 'function') {
aFunction();
else if (typeof(aFunction) == 'string') {
eval(aFunction);
else {
var e = new mb_exception("FunctionArray.execute: Invalid parameter:
" + aFunction);
this.remove = function (functionString) {
var listLength = this.count();
for (var i = listLength - 1; i >= 0; i--) {
if (this.get(i) == functionString){
this.del(i);
Baudson Christoph
http://www.wheregroup.com
More information about the Mapbender_dev
