[Mapbender-dev] JavaScript compression
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Thu May 24 05:52:35 EDT 2007
To enable Mapbender to load faster, the new release will employ
JavaScript compression.
There has been a lot of discussion about this in the past; I think
packing the JS files with JSMin is the best idea:
http://www.crockford.com/javascript/jsmin.html
+ the existing JS code must not stick to a given syntax
+ transparent (removes only linefeeds, whitespaces and comments)
+ no obfuscation
0 compared to real packers with still a good compression rate.
Files that are already compressed with other packers (like jQuery) will
of course not be re-compressed.
Some more questions arise:
1) Where to store the compressed/uncompressed files in the file system.
The default setting should be "compressed" IMHO. It should be easy to
switch back and forth from uncompressed to compressed.
2) Which settings? Take a look at
http://fmarcia.info/jsmin/test.html
You can add comments. The compressed JS files will not have a license
on top of the script, as comments are removed. Do we have to add a license?
For compression settings, I chose "conservative" for my test run; Some
scripts like jsTree.js don't use the ; to end statements, so a linefeed
mustn't be removed.
Any ideas?
Christoph
More information about the Mapbender_dev
