[Mapbender-dev] JavaScript compression
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Wed May 30 11:45:59 EDT 2007
thanks for your suggestion, Marc.
I have checked the tool and the compression rates are better than JSMin's.
While JSMin compressed my sample file (map.js, around 60K) to 70%,
Shrinksafe made it to around 60%. I think I will try to compress the
relevant files with both and want to see if there is a difference. If
not, then Shrinksafe is definitely a good choice.
I have also found a nice online interface at
http://alex.dojotoolkit.org/shrinksafe/
The next step would be to find an easy way of compressing all the
relevant files in one go, preferably via Eclipse's "Export", as Uli
suggested. How do we proceed? I have created a ticket at
http://trac.osgeo.org/mapbender/ticket/54
Christoph
Marc Jansen schrieb:
> Hi list,
> I would love to see compression brought to the Javascript files and have
> another suggestion as for the compression tool:
> http://dojotoolkit.org/docs/shrinksafe (a nice article which shows how
> to use the compression tool)
> The Java-file custom_rhino.jar is used to pack Javascript. This is used
> within the dojotoolkit (www.dojotoolkit.org) for example. One can
> download the file here:
> http://svn.dojotoolkit.org/dojo/trunk/buildscripts/lib/custom_rhino.jar
> -- Marc
> Christoph Baudson (WhereGroup) schrieb:
>> To enable Mapbender to load faster, the new release will employ
>> JavaScript compression.
>> There has been a lot of discussion about this in the past; I think
>> packing the JS files with JSMin is the best idea:
>> http://www.crockford.com/javascript/jsmin.html
>> + the existing JS code must not stick to a given syntax
>> + transparent (removes only linefeeds, whitespaces and comments)
>> + no obfuscation
>> 0 compared to real packers with still a good compression rate.
>> Files that are already compressed with other packers (like jQuery)
>> will of course not be re-compressed.
>> Some more questions arise:
>> 1) Where to store the compressed/uncompressed files in the file
>> system. The default setting should be "compressed" IMHO. It should be
>> easy to switch back and forth from uncompressed to compressed.
>> 2) Which settings? Take a look at
>> http://fmarcia.info/jsmin/test.html
>> You can add comments. The compressed JS files will not have a license
>> on top of the script, as comments are removed. Do we have to add a
>> license?
>> For compression settings, I chose "conservative" for my test run; Some
>> scripts like jsTree.js don't use the ; to end statements, so a
>> linefeed mustn't be removed.
>> Any ideas?
>> Christoph
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
