[Mapbender-dev] JS Compression
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Wed Nov 7 10:10:44 EST 2007
Marc Jansen schrieb:
> Hi list,
> this is a nice plugin for firefox (firebug needed, i guess).
> http://developer.yahoo.com/yslow/
> It helps to locate performance bottlenecks of webpages.
Thanks for this tool Marc. Hehe, just tried it on Mapbender, and it
scored a straight F :-o
Performance Grade: F (54)
C 1. Make fewer HTTP requests
F 2. Use a CDN
F 3. Add an Expires header
F 4. Gzip components
A 5. Put CSS at the top
B 6. Put JS at the bottom
A 7. Avoid CSS expressions
n/a 8. Make JS and CSS external
A 9. Reduce DNS lookups
B 10. Minify JS
A 11. Avoid redirects
A 12. Remove duplicate scripts
F 13. Configure ETags
> Gzipping (where possible, at best via apache setting, or via
> output_buffering ) would help a lot... as well as would caching.
> -- Marc
> Christoph Baudson (WhereGroup) schrieb:
>> Here's an interesting article on JavaScript compression
>> http://www.julienlecomte.net/blog/2007/08/13/
>> Maybe we should adopt the technique mentioned there. I think
>> especially caching would be very efficient in Mapbender.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Where2B-Konferenz
Die Lösungskonferenz der WhereGroup
am 29. November 2007 in Bonn
http://www.where2b-conference.com
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
olaf.knopp at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
