[Mapbender-dev] Motion: Release plan
Michael Schulz
mschulz at webgis.de
Tue Nov 20 11:21:48 EST 2007
+1 from me
Cheers, Michael
2007/11/20, Christoph Baudson (WhereGroup) <christoph.baudson at wheregroup.com>:
> I motion to adopt the following release plan:
> "Mapbender 2.4.4 will be a bug fix release.
> Mapbender 2.4.4 RC1 will be released on Nov 30, 2007
> Mapbender 2.4.4 stable will be released on Dec 14, 2007
> (Releasing a stable version in mid-December should not be a problem, as
> we are only applying a couple of patches to Mapbender 2.4.3 in order to
> upgrade to 2.4.4 RC1. As it is a bug fix release, there is no need for a
> feature freeze.)
> The feature freeze for Mapbender 2.5 will be Dec 18, 2007.
> Mapbender 2.5 RC1 will be released on Jan 11, 2008
> Mapbender 2.5 stable is planned to be released in March 2008."
> Someone has to second the motion, then the voting begins. Voting ends
> Thursday Nov 29.
> Christoph
> Where2B-Konferenz
> Die Lösungskonferenz der WhereGroup
> am 29. November 2007 in Bonn
> http://www.where2b-conference.com
> _______________________________________
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 17
> Fax: +49 (0)228 / 90 90 38 - 11
> olaf.knopp at wheregroup.com
> http://www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev
