[Mapbender-dev] treeGDE2: opacity
Michael Schulz
mschulz at webgis.de
Wed Oct 24 08:47:30 EDT 2007
with a fresh mapbender 2.4.3 installation we have the following problem:
When opacity_up/down is enabled for the treegde2, and you click the
first time on "opacity down" for a certain wms, the opacity is lowered
to 0 aka the map is fully transparent. Subsequent clicks on opacity
up/down behave normally, i.e. raising/lowering the opacity by steps of
20%.
Is this the intended behaviour?
I can't test this on mapbender.telascience since the test login
doesn't work, but if anyone else could test this and report, I'll open
a ticket for it.
Cheers, Michael
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev
