[Mapbender-dev] Transparent PNG's in IE
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Mon Sep 17 06:21:01 EDT 2007
Hi Markus,
Take a look at this
http://trac.osgeo.org/mapbender/ticket/94
You would have to replace two files. Please report back if this solves
your problem or if it is something different.
Thank you
Christoph Baudson schrieb:
> I'm not sure if it is the same problem, but I've experienced something
> similar in the past: Mapbender uses it's own luminance attributes for the
> map images since version 2.4.2 (as you can set the luminance via
> treeGDE2). But they corrupted existing image luminance, so we had to fix
> it. AFAIR we had to change the files mod_treefolder2.php and map.js, so
> the latest versions from SVN might be worth a try.
> I will take a deeper look at it on Monday and let the list know.
> Christoph
> On Fri, September 14, 2007 11:43 am, "Weißmann, Markus" wrote:
>> Hello,
>> does anybody find a solution to this topic? I want to get following
>> solution in IE, which i get in Mapbender under FF:
>> <http://www.bilder-hochladen.net/files/40qd-1-jpg-nb.html>
>> With GIF i can not go on. If i set on GIF, the areas appear opaque (the
>> same in FF). So it only remains PNG. There was an article already in
>> last year:
>> <http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558.
>> html>
>> http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558.h
>> tml
>> At least i could build the expample (
>> <http://www.twinhelix.com/css/iepngfix/demo/>
>> http://www.twinhelix.com/css/iepngfix/demo/) onto my server. But i could
>> not teach it to Mapbender.
>> With kind regards
>> Deutsch:
>> Hallo,
>> hat jemand zu diesem Thema schon eine Lösung gefunden? Ich möchte
>> folgendes Ergebnis, welches ich in Mapbender unter FF hervorbringen
>> konnte, auch im IE bekommen:
>> Mit GIF komme ich da nicht weiter. Stelle ich auf GIF, erscheinen die
>> Flächen deckend (auch im FF). Also beibt nur PNG. Es gab dazu schon im
>> letzten Jahr einen Beitrag:
>> html>
>> tml
>> Ich habe immerhin das Beispiel (
>> http://www.twinhelix.com/css/iepngfix/demo/) auf meinem Server
>> nachvollziehen können. Aber ich konnte es Mapbender nicht beibringen.
>> Mit freundlichem Gruß
>> Markus Weißmann
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:info at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Baudson Christoph
More information about the Mapbender_dev
