[Mapbender-dev] Transparent PNG's in IE
Samson, Marko
Marko.Samson at wald-und-holz.nrw.de
Tue Sep 18 04:34:47 EDT 2007
where did you copy the map.js file?
There should be a map.js in mapbender/http/javascripts/
Gruß,
Marko Samson
Marko Samson
Landesbetrieb Wald und Holz NRW
GIS-Anwendungsentwicklung
Referat I-5
Albrecht-Thaer-Straße 34
48147 Münster
Tel.: 0251/91797 - 169
Mail: marko.samson at wald-und-holz.nrw.de
From: mapbender_dev-bounces at lists.osgeo.org [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of "Weißmann, Markus"
Sent: Tuesday, September 18, 2007 10:18 AM
To: mapbender_dev at lists.osgeo.org
Subject: [Mapbender-dev] Transparent PNG's in IE
Hello Christoph,
i replaced the two files. The file called "mod_treefolder2.php" already exists in my filesystem, so i could replace it, but "map.js" was not there, so i created it new. But there was no effect.
Markus
>Hi Markus,
>Take a look at this
>http://trac.osgeo.org/mapbender/ticket/94 <http://trac.osgeo.org/mapbender/ticket/94>
>You would have to replace two files. Please report back if this solves
>your problem or if it is something different.
>Thank you
>Christoph Baudson schrieb:
>> I'm not sure if it is the same problem, but I've experienced something
>> similar in the past: Mapbender uses it's own luminance attributes for the
>> map images since version 2.4.2 (as you can set the luminance via
>> treeGDE2). But they corrupted existing image luminance, so we had to fix
>> it. AFAIR we had to change the files mod_treefolder2.php and map.js, so
>> the latest versions from SVN might be worth a try.
>> I will take a deeper look at it on Monday and let the list know.
>> Christoph
>> On Fri, September 14, 2007 11:43 am, "Weißmann, Markus" wrote:
>>> Hello,
>>> does anybody find a solution to this topic? I want to get following
>>> solution in IE, which i get in Mapbender under FF:
>>> <http://www.bilder-hochladen.net/files/40qd-1-jpg-nb.html <http://www.bilder-hochladen.net/files/40qd-1-jpg-nb.html> >
>>> With GIF i can not go on. If i set on GIF, the areas appear opaque (the
>>> same in FF). So it only remains PNG. There was an article already in
>>> last year:
>>> <http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558 <http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558> .
>>> html>
>>> http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558.h <http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558.h>
>>> tml
>>> At least i could build the expample (
>>> <http://www.twinhelix.com/css/iepngfix/demo/ <http://www.twinhelix.com/css/iepngfix/demo/> >
>>> http://www.twinhelix.com/css/iepngfix/demo/ <http://www.twinhelix.com/css/iepngfix/demo/> ) onto my server. But i could
>>> not teach it to Mapbender.
>>> With kind regards
>>> Deutsch:
>>> Hallo,
>>> hat jemand zu diesem Thema schon eine Lösung gefunden? Ich möchte
>>> folgendes Ergebnis, welches ich in Mapbender unter FF hervorbringen
>>> konnte, auch im IE bekommen:
>>> Mit GIF komme ich da nicht weiter. Stelle ich auf GIF, erscheinen die
>>> Flächen deckend (auch im FF). Also beibt nur PNG. Es gab dazu schon im
>>> letzten Jahr einen Beitrag:
>>> html>
>>> tml
>>> Ich habe immerhin das Beispiel (
>>> http://www.twinhelix.com/css/iepngfix/demo/ <http://www.twinhelix.com/css/iepngfix/demo/> ) auf meinem Server
>>> nachvollziehen können. Aber ich konnte es Mapbender nicht beibringen.
>>> Mit freundlichem Gruß
>>> Markus Weißmann
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev <http://lists.osgeo.org/mailman/listinfo/mapbender_dev>
>WhereGroup GmbH & Co. KG
>Siemensstraße 8
>53121 Bonn
>Germany
>Fon: +49 (0)228 / 90 90 38 - 17
>Fax: +49 (0)228 / 90 90 38 - 11
><mailto:info at wheregroup.com <mailto:info at wheregroup.com> >
>http://www.wheregroup.com <http://www.wheregroup.com>
>Amtsgericht Bonn, HRA 6788
>Komplementärin:
>WhereGroup Verwaltungs GmbH
>vertreten durch:
>Arnulf Christl, Olaf Knopp, Peter Stamm
>Baudson Christoph
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20070918/f4689fbb/attachment-0001.html
More information about the Mapbender_dev
