AW: [Mapbender-dev] Transparent PNG's in IE
"Weißmann, Markus"
Markus.Weissmann at LGN.Niedersachsen.de
Wed Sep 19 02:23:29 EDT 2007
Hi Christoph,
i installed Mapbender 2.4.2 and replaced the two files but i did not
notice any effect again. I also did not notice any effect between the
normal 2.4.2 version and the version after the replacement.
I tested the new function about the dynamic opacity. That was the
result:
100% opacity
<http://bildrian.de/n/b/8f649a7d594953a9.gif>
80% opacity
<http://bildrian.de/n/b/10d96438dcf96106.gif>
With kind regards
Markus Weißmann
>Hi Markus,
>Take a look at this
> <http://trac.osgeo.org/mapbender/ticket/94>
>You would have to replace two files. Please report back if this solves
>your problem or if it is something different.
>Thank you
>Christoph Baudson schrieb:
>> I'm not sure if it is the same problem, but I've experienced
something
>> similar in the past: Mapbender uses it's own luminance attributes for
the
>> map images since version 2.4.2 (as you can set the luminance via
>> treeGDE2). But they corrupted existing image luminance, so we had to
fix
>> it. AFAIR we had to change the files mod_treefolder2.php and map.js,
so
>> the latest versions from SVN might be worth a try.
>> I will take a deeper look at it on Monday and let the list know.
>> Christoph
>> On Fri, September 14, 2007 11:43 am, "Weißmann, Markus" wrote:
>>> Hello,
>>> does anybody find a solution to this topic? I want to get following
>>> solution in IE, which i get in Mapbender under FF:
>>> < <http://www.bilder-hochladen.net/files/40qd-1-jpg-nb.html>
>>> With GIF i can not go on. If i set on GIF, the areas appear opaque
(the
>>> same in FF). So it only remains PNG. There was an article already in
>>> last year:
<http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558>
http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558.
>>> html>
<http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558.
h>
http://lists.osgeo.org/pipermail/mapbender_users/2006-September/000558.h
>>> tml
>>> At least i could build the expample (
>>> < <http://www.twinhelix.com/css/iepngfix/demo/>
http://www.twinhelix.com/css/iepngfix/demo/) onto my server. But i could
>>> not teach it to Mapbender.
>>> With kind regards
>>> Deutsch:
>>> Hallo,
>>> hat jemand zu diesem Thema schon eine Lösung gefunden? Ich möchte
>>> folgendes Ergebnis, welches ich in Mapbender unter FF hervorbringen
>>> konnte, auch im IE bekommen:
>>> Mit GIF komme ich da nicht weiter. Stelle ich auf GIF, erscheinen
die
>>> Flächen deckend (auch im FF). Also beibt nur PNG. Es gab dazu schon
im
>>> letzten Jahr einen Beitrag:
>>> html>
h>
>>> tml
>>> Ich habe immerhin das Beispiel (
http://www.twinhelix.com/css/iepngfix/demo/) auf meinem Server
>>> nachvollziehen können. Aber ich konnte es Mapbender nicht
beibringen.
>>> Mit freundlichem Gruß
>>> Markus Weißmann
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> <http://lists.osgeo.org/mailman/listinfo/mapbender_dev>
>WhereGroup GmbH & Co. KG
>Siemensstraße 8
>53121 Bonn
>Germany
>Fon: +49 (0)228 / 90 90 38 - 17
>Fax: +49 (0)228 / 90 90 38 - 11
> <mailto:info> mailto:info at wheregroup.com
> <http://www.wheregroup.com> http://www.wheregroup.com
>Amtsgericht Bonn, HRA 6788
>Komplementärin:
>WhereGroup Verwaltungs GmbH
>vertreten durch:
>Arnulf Christl, Olaf Knopp, Peter Stamm
>Baudson Christoph
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20070919/fd6802d8/attachment.html
More information about the Mapbender_dev
