[Mapbender-dev] Fwd: [Mapbender-users] problems at creating mapbender2.5 schema
Michael Schulz mschulz at webgis.de
Thu Apr 17 12:05:45 EDT 2008
i've found this:
http://andreas.scherbaum.la/blog/archives/346-create-language-if-not-exist.html
Haven't tried it though, but it looks good.
Cheers, Michael
---------- Forwarded message ----------
Date: 2008/4/17
Subject: Re: [Mapbender-users] problems at creating mapbender2.5 schema
To: Mapbender User List <mapbender_users at lists.osgeo.org>
Hi Marc,
 the mapbender database must have the plpgsql language installed,
 because of the i18n functions. If your db has plpgsql already
 installed, then you can comment this statement from the schema.sql.
 We should have look for a "check if exists" way to do this, because a
 lot of people will have plpgsql installed (e.g. from postgis).
 Cheers, Michael
 2008/4/17 Marec <marec at t-online.de>:
> Hi list,
 >  i actually downloaded  the new mapbender(2.5rc1) release.
 >  Now i have a problem at creating the new Database schema.
 >  If  i execute the "pgsql_schema.sql" i get following error message:
 >  ERROR:  language "plpgsql" already exists
 >  Is the first statement a mandatory setting in the new release or can i
 > delete it??
 >  Because I couldn't find the first statemets in older releases.
 >  greetings Marc
 >  _______________________________________________
 >  Mapbender_users mailing list
 >  Mapbender_users at lists.osgeo.org
 >  http://lists.osgeo.org/mailman/listinfo/mapbender_users
 Michael Schulz
 in medias res
 Gesellschaft für Informationstechnologie mbH
 In den Weihermatten 66
 79108 Freiburg
 Tel +49 (0)761 556959-5
 Fax +49 (0)761 556959-6
 http://www.webgis.de / http://www.zopecms.de
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_dev mailing list
