[Mapbender-dev] Fwd: [Mapbender-users] problems at creating
mapbender2.5 schema
Michael Schulz
mschulz at webgis.de
Fri Apr 18 11:49:44 EDT 2008
Hi Christoph,
plpgsql is one language with that you can create functions.However
this check creates a temporary "sql" function to determine whether
plpgsql is installed. So you won't need plpgsql installed.
Cheers, Michael
2008/4/18 Christoph Baudson <christoph.baudson at wheregroup.com>:
> Michael Schulz schrieb:
> > Hi,
> > i've found this:
> http://andreas.scherbaum.la/blog/archives/346-create-language-if-not-exist.html
> > Haven't tried it though, but it looks good.
> > Cheers, Michael
> Thanks for your suggestion Michael, however I fear that his solutions is no
> good, if I read the comments correctly...he used a function to check if
> plpgsql is there. But plpgsql is required for functions.
> But another poster seems to have submitted a patch to PostgreSQL, let's see
> if we have this is in the next version.
> For now, I have removed the CREATE LANGUAGE bit, as it is listed in the
> installation guide.
> Have a nice weekend,
> Christoph
> > ---------- Forwarded message ----------
> > From: Michael Schulz <mschulz at webgis.de>
> > Date: 2008/4/17
> > Subject: Re: [Mapbender-users] problems at creating mapbender2.5 schema
> > To: Mapbender User List <mapbender_users at lists.osgeo.org>
> > Hi Marc,
> > the mapbender database must have the plpgsql language installed,
> > because of the i18n functions. If your db has plpgsql already
> > installed, then you can comment this statement from the schema.sql.
> > We should have look for a "check if exists" way to do this, because a
> > lot of people will have plpgsql installed (e.g. from postgis).
> > Cheers, Michael
> > 2008/4/17 Marec <marec at t-online.de>:
> > > Hi list,
> > > i actually downloaded the new mapbender(2.5rc1) release.
> > > Now i have a problem at creating the new Database schema.
> > > If i execute the "pgsql_schema.sql" i get following error message:
> > > ERROR: language "plpgsql" already exists
> > > Is the first statement a mandatory setting in the new release or can i
> > > delete it??
> > > Because I couldn't find the first statemets in older releases.
> > > greetings Marc
> > > _______________________________________________
> > > Mapbender_users mailing list
> > > Mapbender_users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> > Michael Schulz
> > in medias res
> > Gesellschaft für Informationstechnologie mbH
> > In den Weihermatten 66
> > 79108 Freiburg
> > Tel +49 (0)761 556959-5
> > Fax +49 (0)761 556959-6
> > http://www.webgis.de / http://www.zopecms.de
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_dev
