[Mapbender-dev] mark deprecated functions
Christoph Baudson
christoph.baudson at wheregroup.com
Mon Apr 21 09:49:54 EDT 2008
Hi Thomas,
Thomas Baschetti schrieb:
> Hi,
> as more and more functions or modules in mapbender
> are deprecated i think it would be useful to mark
> these clearly and visible to all admins. What i'm thinking
> about is something like throwing a notice in the deprecated
> module, e.g. in class_administration.php
> something like this
> * @deprecated
> function getGuisByPermission($mb_user_id,$ignorepublic){
> $e = new mb_notice("administration->getGuisByPermission is deprecated, use user->getGuisByPermission instead!");
> $user = new User($mb_user_id);
> return $user->getApplicationsByPermission($ignorepublic);
> so if the dev or admin reads the logfiles this will get obvious
> (reading logs anyone? ;-)
> What do you think about this?
As a developer, I'm indifferent about it (I'm not a user). But I see
your point.
There are a lot of files to check, and I wouldn't want to go through all
of them. But if you work on a file that contains a deprecated function,
just go ahead and add the notice to it.
Maybe we should move the discussion to the user list?
Thanks
Christoph
> Ciao
> Thomas Baschetti
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
