[Mapbender-dev] bug in function char_encode (Ticket #210)
Christoph Baudson
christoph.baudson at wheregroup.com
Wed Apr 23 03:44:00 EDT 2008
David Arndt schrieb:
> I had problems with "umlauts" in Mapbender 2.5rc1 und rc2.
> When I comment:
> /*if (CHARSET == "UTF-8") {
> if (!$this->is_utf8($data)) {
> $e = new mb_notice("Conversion: ISO-8859-1 to UTF-8");
> return utf8_encode($data);
> else {
> if ($this->is_utf8($data)) {
> $e = new mb_notice("Conversion: UTF-8 to ISO-8859-1");
> return utf8_decode($data);
> in function char_encode($data) in class_administration.php,
> it works for me. But I don't know if this works in iso8859-1
> installations.
Thanks David,
at what point did you encounter these umlaut problems? We should take a
closer look at that module and the input data. Do you have an online demo?
At this point I assume char_encode works ok.
Christoph
> Regards, David.
> geoinformation+planung
> reichert+partner ingenieure
> gölzstr. 22 72072 tübingen
> fon: +49 (0)7071-407360
> fax: +49 (0)7071-407361
> info at geoinformation-planung.de
> http://www.geoinformation-planung.de
> Regionalplan Schwarzwald-Baar-Heuberg online:
> http://www.regionalplan-sbh.de
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
