[Mapbender-dev] JSON RPC
Christoph Baudson
christoph.baudson at wheregroup.com
Mon Dec 1 05:25:49 EST 2008
Has been approved by the PSC, see
http://logs.qgis.org/mapbender/%23mapbender.2008-11-10.log
Closed.
Christoph Baudson schrieb:
> Hello,
> although Mapbender is wanting to move towards a RESTful architecture,
> I fear it will not happen until a version 3.0.
> In the meantime, I propose to use JSON RPC
> (http://en.wikipedia.org/wiki/JSON-RPC) as the standard protocol to
> use for internal client server interactions. It's very close to what
> we are doing now.
> Using a standardised exchange format will have the following advantages
> * less error prone
> * faster to implement AJAX code
> * define standard error messages (example: session times out; then a
> user clicks a button, an AJAX request is triggered; the server side
> replies that the session is expired with a well defined error code;
> client responds to the error code and displays a standard message. You
> don't want to do this manually for each AJAX call)
> I'm open to any other suggestions. I think using a wrapper is
> inevitable. Please send your opinions and suggestions until Monday,
> Nov 10.
> Thanks
> Christoph
Where2B-Konferenz
Die Geo-IT Konferenz der WhereGroup
vom 9.-10. Dezember 2008 in Bonn
Web: www.where2b-conference.com
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
