[Mapbender-dev] Wiki: Please review
Christoph Baudson christoph.baudson at wheregroup.com
Mon Dec 8 11:19:46 EST 2008
Hi Johannes,
Thanks for this incredible tutorial, very helpful indeed. A lot of new
information for me to stomach. I will need some time to understand every
detail of your contribution, but thanks a lot!
Christoph
Hr. Johannes Loose schrieb:
> Hello Devs!
> I'm am trying to install a secure webgis environment since a while. The main steps are
> documented now and I'd like to share them with the community. Note that I'm neither a
> programmer, nor a security expert.
> I have uploaded a draft (So long German only, sorry) in the mapbender wiki, knowing, that lot
> of the information is documented in some other place in the same wiki. The howto is
> designed for advanced users, not as a step-by-step instruction. You can find it here :
> http://www.mapbender.org/SecureInstall
> If you find it useful, you might correct some points or tell me what to make better. If you find
> some errors or wrong statements, please let me know and correct them. Feel free to contact
> me directly, too. I would like to know if the way I did it is 'quite secure' or if there are obvious
> holes.
> In case there is no benefit for other users, well just press 'delete'
> Yours
> Johannes
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Where2B-Konferenz
Die Geo-IT Konferenz der WhereGroup
vom 9.-10. Dezember 2008 in Bonn
Web: www.where2b-conference.com
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
