[Mapbender-dev] console.log vs new Mb_notice
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Dec 19 05:00:03 EST 2008
When debugging new Mapbender functionality, most developers I know use
Firebug's
console.log
to do so. I recommend not to use it. In a non Firebug environment, your
code will fail. And I don't want to add code to Mapbender that checks if
console is defined etc.
You can use "new Mb_notice('text')" instead. Just configure your
mapbender.conf to log notices and set the LOG_JS constant to "console".
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
