[Mapbender-dev] Changes in Wiki URL syntax
Arnulf Christl
arnulf.christl at wheregroup.com
Fri Feb 1 10:32:52 EST 2008
we have finally changed the Wiki URL syntax omitting the "index.php". This has been on our task list for quite some time. It makes URL more readable, easier to memorize and also seems to be more friendly to search engines.
Please check through your usual bookmarks, etc. everything *should* still work without any changes. If we broke anything please let us know!
>From now on you should point external links directly to the Wiki page name in question. See these examples:
Old:
http://www.mapbender.org/index.php/Mailing_List
New:
http://www.mapbender.org/Mailing_List
A big thanks to Dietmar for doing this.
Best regards,
Arnulf.
More information about the Mapbender_dev
