[Mapbender-dev] Motion to change terminology: "Application" instead of "GUI"
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Tue Feb 19 02:53:24 EST 2008
Arnulf Christl schrieb:
> Hello,
> as discussed earlier on IRC I propose to change the terminology use din
> Mapbender WIki, documentation, presentations, etc. from "GUI" to
> "Application".
> Motion to change Mapbender terminology from "GUI" to "Application".
Seconded and +1.
> The rationale is that "GUI" is not a term well known to end users and it
> does not reflect what a Mapbender applicaiton actually is - namely an
> Application.
> A "Graphic User Interface" by definition needs to have somethign visible
> to the user. In many cases Mapbender "GUI" do not have an interface fo
> rthe user but are just containers to structure permissions or to be used
> as sources for catalogs. To call this a "GUI" is simply wrong (for example
> wms_africa).
> Mapbender is a framework to create, maintain and operate separate
> applications that can use the same services. The idea is that the
> application contains not only graphic user interfaces but also services
> that can be configured individually and functionality that is designed for
> a specific use case - and application.
> An application is focused on a work flow or process whereas a GUI is just
> the graphic user interface. Mapbender "GUI"s have links to services,
> functionality and even users, groups and user rights. This is a lot more
> than what the term GUI can convey.
> What will this change break?
> All existing users of Mapbender will have to learn that what was a "GUI"
> is now an "Application". But we are well connected to all existing users,
> so informing them is easy.
> What good will this change do?
> It will be much easier to explain what Mapbender is good for. Its good to
> build applications. Sentences like "Please open your guigui" or "Please
> open your guiguione" will not bother us anymore. So it will help to
> attract people to look into Mapbender because they know that an
> application is more than just yet another interface.
> With Mapbender growing to be more of a management, security and brokering
> system we should get rid of the confining term GUI.
> Please take you time to discuss this in detail.
> Regards,
FOSSGIS Konferenz
Freie und Open Source Software für GIS
vom 01.-03. April 2008 in Freiburg
www.fossgis.de
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
