[Mapbender-dev] where updating fails
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Fri Jan 4 07:53:10 EST 2008
Christoph Baudson (WhereGroup) schrieb:
> The update process is very painful at the moment. I start this thread
> to gather where things go wrong. Please add, so we can find out what
> we have to improve.
> Example: in Mapbender 2.5 we have a new table gui_wfs_conf. In the
> current update script we have a line like this
> INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES
> ('gui_digitize', 1);
> which links the GUI "gui_digitize" to wfs_conf with Id 1. This is done
> to restrict access to this WFS conf to users who have access to
> "gui_digitize".
> Of course, an update SQL should link "all" GUIs that use configured
> WFS. As far as I can see, we would need to check the element vars for
> wfs_conf_id_string, see if the wfs conf id is listed, and then link
> them. Tricky, at least in SQL.
Another problem are configuration files. If there are new entries, how
do they get into existing conf files?
For example, Mapbender 2.5 will have new variables in "wfs_default.conf"
and "digitize_default.conf".
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
