[Mapbender-dev] Re: How to include license text?
Arnulf Christl
arnulf.christl at wheregroup.com
Thu Jan 10 08:44:15 EST 2008
Michael Schulz wrote:
> Dear Arnulf,
> in yesterdays irc-meeting we were discussing if and how the header of
> each file should or must include the license text.
> Most participants favored a link to the license text, that would be
> inlcuded in the header in phpDoc style:
> * $Id: class_kml_point.php 1948 2008-01-03 16:35:29Z christoph $
> * @link http://www.mapbender.org/index.php/class_kml_point.php
> * @copyright 2002 CCGIS
> * @license http://opensource.org/licenses/gpl-license.php
> Should a link in the header point to a local file or to an URL (Marc
> suggested the URL of the original GPL v3). Both links should also be
> possible.
> Finally everyone wanted to hear the opinion of an expert (unanimous:
> Arnulf), whether there are legal implications that need to be
> respected.
> It would be great if you could comment on that issue.
> Cheers, Michael
Hello,
I have been out of the Mapbender context for some time, sorry for that. I will look into this issue and report back until the next IRC meeting.
As a side note: We started off as GPL V2 and should carefully consider whether we want to simply upgrade to V3 without any discussion. I would suggest to not add any explicit links to GPL V3 right now.
Best regards,
Arnulf.
> Hallo Arnulf,
> wir hatten gestern im IRC-Chat eine Diskussion, darüber wie und ob im
> Header jedes Files der License-Text stehen soll bzw. muss.
> Die meisten waren der Meinung, dass ein Link zu dem Text der Lizenz
> ausreichen sollte. Der Link würde im phpDoc-Stil in den Header
> eingebaut (aus Mail von Christoph) etwa so:
> Dann tauchte die Frage auf, ob der Link zu einem lokalen Lizenz-File
> zeigen sollte, oder zu einer URL (Marc schlug den Link zur
> Original-GPL v3 vor). Evtl. wäre ja auch beides möglich.
> Letztendlich wollten alle noch die Meinung eines Experten (einstimmig:
> Arnulf) hören, ob es da noch Legales zu beachten gilt und wenn ja,
> was.
> Es wäre gut deine Ansicht zu hören.
> Viele Grüße, Michael
More information about the Mapbender_dev
