[Mapbender-dev] Cleaning up the WMS contained in the MB default database
Michael Schulz mschulz at webgis.de
Mon Jan 14 09:42:43 EST 2008
couldn't we extract this wms default data (maybe except the wms needed
for gui, gui1, gui2) from the data.sql script? When starting with a
mapbender database one does not necessarily need all those wms.
Maybe we could create a php-script, that will properly load the
additional wms and not just insert them via SQL, e.g as a step in an
upcoming setup-script? That would also eliminate not-existing or
outdated wms.
Cheers, Michael
2008/1/14, Arnulf Christl <arnulf.christl at wheregroup.com>:
> Hi,
> when preparing a demo for a client I noticed that quite a few WMS that are in the Mapbender default database are outdated, fail to load, have errors or load really slow. In the past years this database has not been maintained well and it badly needs a cleanup and maybe more services could be added. Whose job is this?
> Best regards,
> Arnulf.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
