[Mapbender-dev] Discussion: Character sets (client encoding)
Christoph Baudson
christoph.baudson at wheregroup.com
Thu Jul 17 03:15:42 EDT 2008
>>>> This is a proposal to serve UTF-8 encoded HTML pages only. In my
>>>> opinion there is no need to serve ISO-8859-1 pages.
>>>> All character set conversions (when interacting with a database)
>>>> could be done in PHP. So the architecture would change from
>>>> client: ISO/UTF8
>>>> server: UTF8
>>>> database: ISO/UTF8
>>>> to
>>>> client: ISO/UTF8
>>>> server: UTF8
>>>> database: ISO/UTF8
>>>> This will simplify things a lot and would make Mapbender less
>>>> error-prone. If anyone has any reason why we should still serve ISO
>>>> pages, please step up. I have no idea why we should.
>>>> Thanks,
>>>> Christoph
>>> You confuse me, I cannot see the difference?
>> neither do I.
>> Here's what I meant
>> client: UTF8
>> server: UTF8
>> database: ISO/UTF8
>> Christoph
>> nr: copy and paste for beginners
> I am just wondering - what is the reason that we need an ISO database
> dump at all? Why do we have it?
Legacy. If even you consider dropping it, we really should.
> Obviously all who currently have an ISO database would need to convert
> to UTF8 and this is painful but if we can implement a good migration
> path this should be manageable.
> Unfortunately the Mapbender architecture is way more complex than just
> client, server and database. What happens to WMS that serve ISO
> encoded FeatureInfo results through the Mapbender tunnel. Or if you
> have one ISO and one UTF8 in the tunnel? WFS with GML that contains
> ISO encoded text. The full set of encoding trouble is a quite a stack
> indeed.
> If it is just the three mentioned layers I am all in favor.
In my opinion the server side is responsible for converting incoming
data to UTF8. I mentioned database only, but of course you are right,
there is much more.
Anything that works encoding-wise in Mapbender now is based on pure
chance, so it can't get any worse.
Christoph
> +1
> Regards, Arnulf.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
