[Mapbender-dev] RE: [Mapbender] #212: capabilities-upload does not work
Tilo Wütherich tilo.wuetherich at la-bw.de
Wed Jun 4 05:04:23 EDT 2008
Hi Michael, hi Devs,
>   Reporter:  tow70           |       Owner:  mapbender_dev at lists.osgeo.org
>       Type:  defect          |      Status:  new
>   Priority:  major           |   Milestone:  2.5 release
>  Component:  administration  |     Version:  2.5 rc2
> Resolution:                  |    Keywords:  capabilities umlaute
> Comment (by mschulz):
>  The xml headeres of the cap-doc say this document is utf-8 encoded, which
>  is not the case. Could you change the header and try again?
it works. It must be a bug of the older Geoserver versions. In 1.5.3 I specified charset ISO-8859-1 but regardless GS writes utf-8. With GS 1.6.3 it works properly.
Thank You!
Tilo
More information about the Mapbender_dev mailing list
