[Mapbender-dev] Zoom to full extent
Christoph Baudson
christoph.baudson at wheregroup.com
Thu May 8 05:40:12 EDT 2008
David Arndt schrieb:
> Hi to all,
> I enhanced the function "setExtent". So know it is possible to zoom
> to full extent in other epsg then the first wms epsg. It is not
> perfect, but it works.
> I enhanced the file map.js and there the function setExtent and the
> file php/mod_zoomfull_projection.php (it only works at this time when
> the mapbender database is postgresql with postgis extension enabled).
> I commit this new files to my branch darndt_dev, maybe we can put in
> the next Mapbender.
Thanks for this enhancement! I will take a look at it, then we have to
merge it back into the trunk.
Christoph
> Regards, David.
> geoinformation+planung
> reichert+partner ingenieure
> gölzstr. 22 72072 tübingen
> fon: +49 (0)7071-407360
> fax: +49 (0)7071-407361
> info at geoinformation-planung.de
> http://www.geoinformation-planung.de
> Regionalplan Schwarzwald-Baar-Heuberg online:
> http://www.regionalplan-sbh.de
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
