[Mapbender-dev] Discussion: extending mb_group to contain other
mb_groups as members
Christoph Baudson
christoph.baudson at wheregroup.com
Tue May 27 08:18:37 EDT 2008
At yesterday's IRC meeting we agreed upon adding a new table
"mb_group_mb_group" to model the new relation of groups containing other
groups. We think this is the easiest way which will guarantee fast
results. Another side effect is that we only add a table and not change
existing tables.
BTW, Len, please use the following JS tool to visualize the user/group
relations:
http://blog.thejit.org/wp-content/jit-1.0a/examples/rgraph.html
Just kidding :-) But it looks pretty cool and I wanted to share it.
Christoph
Christoph Baudson schrieb:
> Hi Len,
> I'm sending this to the developer list directly, as a lot of people
> might be interested in joining the discussion.
> Please find my comments inline.
> Len Kne schrieb:
>> Christoph, Lars
>> I've been spending some time looking at the Mapbender developer pages,
>> getting familiar with the jQuery library, and playing with Eclipse. And
>> thinking about the administration modules from 50,000 feet. I do
>> have some
>> questions on the process of getting this large task completed this
>> summer.
>> First, a more specific question. At the Monday IRC meeting Christoph
>> had
>> mentioned that we should make a motion to allow groups to be members of
>> groups. Is this something I can submit to the developer list? If so, I
>> would propose adding a new table to the DB called mb_group_mb_group
>> with two
>> fields similar to the existing mb_user_mb_group table. Minor
>> additions to
>> mb_getGUIs.php would be needed to query this new table and a script
>> similar
>> to mod_group_user.php to allow users to make groups members of
>> groups. If
>> this seems like a good approach, I can write it up more completely.
> We can discuss this at the IRC meeting today.
> I'm not sure. The easiest would be adding a mb_group_mb_group table.
> But maybe we should consider this idea: Imagine there are no users,
> there are only groups. These groups can be arranged hierarchical like
> a tree. The leaves of that tree are called users, the inner nodes are
> called groups. The "is child" relation would then translate to
> "user/group is contained in this group". By this way we could simplify
> the data model (having both mb_user_mb_group and mb_group_mb_group
> would be redundant in a way).
> I think both solutions have their pro's and con's, and maybe someone
> even has a third approach.
>> Back to the big picture of the administration modules. As I
>> mentioned in my
>> proposal I'd like to see a single administration module using tabs to
>> provide hierarchical access to the functions. Commonly used
>> functions (user
>> management, WMS, etc.) would be right up front with some drilling
>> down to
>> get to more advanced functions (GUI elements, WFS customization,
>> etc.). So
>> take admin_de_services, admin1, and admin2_de and combine them into one
>> interface. I'd build off the design (look and use of AJAX) of the new
>> module used to edit WFS. Going even further, using
>> "Internationalization",
>> multiple languages could be supported within a single admin module.
> Just to clarify: what do you mean by "a single administration module"?
> Do you mean just the usage of tabs to wrap existing modules (as it's
> done in the map applications), or really a new module?
> (BTW, do you really want tabs, or wouldn't it be better to have some
> kind of a tree? Basically it's just the same, but it has arbitrary
> depth. I guess the tree used for WMS in the map applications could be
> adjusted - but I'm not sure if you are interested in doing this
> adjustment).
> With the design, we need Lars' help. I guess he has some more
> interesting ideas about HTML validity and elegant CSS usage. Maybe
> Lars can sum up his ideas in a few sentences.
> The internationalization approach is very sensible IMHO, I can help
> with that.
>> Combining the admin functions into one module could cause an issue with
>> giving rights to users to do certain administrative tasks. Currently,
>> access can be controlled to the administrative GUI's, thus
>> restricting what
>> users can do. If all of the functionality was in one module (like
>> admin1
>> currently has), some users may be able to get into too much of the
>> administration. I could see handling this issue with groups by
>> restricting
>> certain tabs or functions within the new administration module to
>> specific
>> group membership.
> First of all, each single module has to check the permissions of the
> current user. So if a user tries to access a module and has no valid
> permission, the module will not be accessible. And beware: The
> application "admin1" is supposed to be a container only! It should
> only be used as a template for creating your own administration
> interfaces (but I guess we have not made this clear enough in
> Mapbender - maybe we should add a column "isTemplate" to the table
> gui? We could avoid displaying these template applications then).
> So your approach is an "intelligent" tab structure which detects the
> module permissions and only displays the valid entries? I'm not sure
> about this, as this sounds like a contradiction to the current
> Mapbender approach, which is "grant permissions to modules by granting
> permission to applications containg these modules".
> What I'm trying to say is this: If you grant a user access to this
> "über" admin application (which contains all modules, like admin1),
> this user also has permission to ALL modules (as there is no
> mb_user_element table). Would it make sense to have a mb_user_element
> table? I guess not really, as this would create quite an
> administration overhead. But if you have another idea, I'm glad to
> discuss it.
> I think it's important to discuss these issues intensely up front, so
> there are no misunderstandings. We should not hurry with design. I
> guess once we have figured out what we want, coding can be done really
> fast.
>> My thought is to write-up these ideas in a more coherent text and
>> send it to
>> both the users and developers list for comment. What is the norm for
>> Mapbender development? When starting to code, I was planning on
>> starting
>> with users and groups as they probably will not be greatly affected
>> by the
>> proposed changes to "elements".
> Yes, this may be a good place to start. Let's discuss this idea first
> and later this week we send a motion to the dev list. After this, we
> can start coding.
>> I guess that's enough for now. I'm going to try start getting to work
>> earlier (although not on Thursday this week) so there will be more
>> chance of
>> catching people on IRC (Minneapolis is UTC-6).
> If you feel the need for discussion, we can make an additional
> appointment at a more appropriate time. I would be happy to join IRC
> later from home, I could be available sometime between 1300 and 1500
> Minneapolis time, just let me know up front and we can meet and discuss.
>> Thanks
>> Len
>> -----Original Message-----
>> From: Christoph Baudson [mailto:christoph.baudson at wheregroup.com]
>> Sent: Wednesday, May 21, 2008 6:31 AM
>> To: Len Kne
>> Cc: Lars Beck (WhereGroup)
>> Subject: GSoC Mapbender
>> Hi Len,
>> as you will be working on the administration modules, you will also
>> have to
>> consider layout and styles.
>> I'm cc'ing this mail to Lars, who is your co-mentor; he can help you
>> with
>> CSS and generally creating a visual concept.
>> Thanks
>> Christoph
>> _______________________________________
>> W h e r e G r o u p GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Christoph Baudson
>> Anwendungsentwickler
>> Fon: +49 (0)228 / 90 90 38 - 15
>> Fax: +49 (0)228 / 90 90 38 - 11
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Arnulf Christl, Olaf Knopp, Peter Stamm
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
www.wheregroup.com
Komplementärin:
vertreten durch:
More information about the Mapbender_dev
