[Mapbender-dev] Relation map object / wms object
Michael Schulz mschulz at webgis.de
Tue May 27 11:44:44 EDT 2008
Hi Christoph,
> This means that you have at least one WMS in two or more map objects, so
> manipulating it in a single map also alters it in the other. I assume
I tought, that only manipulation done in the wms_gui_settings change
the wms in both map objects (i.e. prior to loading the gui). When a
gui is loaded the wms in the different map objects can be changed
without affecting each other - otherwise changes to the wms in the
main mapframe via treegde would change the overview mapframe
accordingly. That is not the case.
> removing the global WMS object and storing the data in each map object would
> be more consistent.
I think your suggestion makes perfect sense. But wouldn't it create a
need for a more complex gui administration interface? Configure the
wms for map object x in application y. Although i think that would be
really powerful. At the moment the wms configuration for the overview
frame is pretty distributed and has a lot of additional magic when
accompanied by certain modules (dynamicOverview, SetBackground).
Cheers, Michael
> Please enlighten me if you have an explanation why the current solution is
> superior.
> Christoph
> _______________________________________
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> christoph.baudson at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
