[Mapbender-dev] Relation map object / wms object
Christoph Baudson
christoph.baudson at wheregroup.com
Wed May 28 04:54:05 EDT 2008
Michael Schulz schrieb:
> Hi Christoph,
>> I believe the administration tool does not have to be altered. Maybe I have
>> to explain the background of my previous post: I'm working on web map
>> context documents, which store the layers of the client in an XML document.
>> When I'm representing both map frames (plus their layer settings) in the WMC
>> document, I have no way of finding out the layer settings of the overview.
>> The default settings are overwritten by changes made to the main map.
>> Example: Assume a WMS is available in both overview and the main map. Then
>> hide layers of that WMS via the treeGDE module.
> Just to be curious, does the wmc spec have an option to store
> information about an overview? I thought this is merely a flat list of
> layers ...
It is a flat list of layers. We plan to store the information whether a
layer belongs to the overview in an extension tag. Currently, it is just
based on karma.
> Although you could put together a context collection with one wmc for
> each mapobject. In that case you are right, wms setting changes
> shouldn't cross map object scopes.
Unfortunately, context collection only have links (URLs) to other WMC
documents. The documents cannot be stored in-line. We have asked the OGC
context revision workgroup to change this behaviour for future specs.
>> Other solutions could be discussed, like
>> * reload the default settings from the database
>> * always show all layers of the overview WMS
> For me, a wmc makes sense if it stores the current layer settings, not
> some initial default, but presumably you have a special focus.
The problem is that the current settings for the overview are not
available (anymore) in the client. So by reloading them from the
database, I would just fake having the current settings.
Christoph
>> but both solutions don't seem elegant to me, especially if you imagine
>> having 7 maps and 3 overviews in one applications.
> wow, i'd like to see that one ... ;-)
> Michael
>> I believe when Mapbender had been designed it was not intended to ever do
>> sth. with the overview window after its instantiation, so then it made
>> perfect sense. Now, we need more.
>>> Cheers, Michael
>>>> Please enlighten me if you have an explanation why the current solution
>>>> is
>>>> superior.
>>>> Christoph
>>>> _______________________________________
>>>> W h e r e G r o u p GmbH & Co. KG
>>>> Siemensstraße 8
>>>> 53121 Bonn
>>>> Germany
>>>> Christoph Baudson
>>>> Anwendungsentwickler
>>>> Fon: +49 (0)228 / 90 90 38 - 15
>>>> Fax: +49 (0)228 / 90 90 38 - 11
>>>> www.wheregroup.com
>>>> Amtsgericht Bonn, HRA 6788
>>>> Komplementärin:
>>>> WhereGroup Verwaltungs GmbH
>>>> vertreten durch:
>>>> Arnulf Christl, Olaf Knopp, Peter Stamm
>>>> _______________________________________________
>>>> Mapbender_dev mailing list
>>>> Mapbender_dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Christoph Baudson
>> www.wheregroup.com
>> Komplementärin:
>> vertreten durch:
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
www.wheregroup.com
Komplementärin:
vertreten durch:
More information about the Mapbender_dev
