[Mapbender-dev] New module mapdiv (Mapbender without iframes)
Christoph Baudson christoph.baudson at wheregroup.com
Thu Oct 9 04:24:11 EDT 2008
At the recent development sprint nimix and I worked on an improved map
module. The difference is, that it will be a div, and no longer an iframe.
There are still some modules we need to adjust in order to work with new
map module. One challenge is, for example, the change from absolute
positioning (within a frame) to a relative positioning (relative to the
div). Nimix and I consider this to be another day or two.
If you have any questions on this module or the implied changes, please
reply on-list.
In my opinion we should replace the existing map module mapframe1 by
this new module. I will add a motion about this in the near future, so
please make sure you are well informed if you plan to vote on the motion.
More info on the development sprint can be found here
http://www.mapbender.org/Mapbender_Development_Sprint
Thanks,
Christoph
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
