[Mapbender-dev] Working with trunk
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Apr 3 02:12:17 EDT 2009
Remember: if you are using trunk, always make sure you have executed the
latest SQLs in
resources/db/update/update_2.7.sql
A lot of things are changing this early in a release cycle.
Thanks
Christoph
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
