[Mapbender-dev] JavaScript beautifier
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Apr 17 11:25:50 EDT 2009
The Mapbender zip archive contains compressed JavaScript files for
better performance. If you need to take a look at the source code, this
is painful. If you haven't changed the source code, you can always get
the code from the tag in the SVN at
https://svn.osgeo.org/mapbender/tags/<version>
If you have changed your JavaScript code, you can always beautify your
code by using this nice tool
http://jsbeautifier.org
This formats the compressed code so that it is human readable again.
Have a nice weekend,
Christoph
ALKIS-kompakt Forum:
Die neue ALKIS-Auskunftslösung
28. April in Bonn
www.alkis-kompakt.de
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
