[Mapbender-dev] [Mapbender] #573: improve HTML with jQuery UI CSS framework
Mapbender mapbender_dev at lists.osgeo.org
Mon Dec 7 12:21:55 EST 2009
 Reporter:  christoph       |       Owner:  dev
     Type:  task            |      Status:  new
 Priority:  major           |   Milestone:  create a new application with state-of-the-art appearance
Component:  administration  |     Version:
 Keywords:                  |
 * understand the jQuery UI CSS framework
  * remove styles from existing modules in application at Telascience
  * remove mapbender.css
  * add appropriate classes to HTML in source code
  * create a custom theme in theme roller and use it in application at
 Telascience
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/573>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
