[Mapbender-dev] [Mapbender] #583: Missing mod_add_SLD breaks use of mb_vendorspecific array
Mapbender mapbender_dev at lists.osgeo.org
Mon Dec 21 10:01:42 EST 2009
 Reporter:  mschulz  |       Owner:  dev
     Type:  defect   |      Status:  new
 Priority:  minor    |   Milestone:  2.6.1
Component:  core     |     Version:  2.6 rc1
 Keywords:           |
 There is a dependency between the module mod_add_SLD.php and the function
 setMapRequest in map_obj.js. the modul add_SLD defines an JS variable
 "removeLayerAndStylesAffectedWMSTitle" that is used in the getMapRequest
 function of map_obj.js. If the module is not activated and you want to use
 your own vendor specific options module, then you get a JS error.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/583>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
