[Mapbender-dev] [Mapbender] #492: getMap Error with Intergraph WMS
mapbender_dev at lists.osgeo.org
Wed Jul 8 04:10:08 EDT 2009
Reporter: marc | Owner: dev
Type: defect | Status: new
Priority: major | Milestone: 2.6 release
Component: administration | Version: 2.6 rc1
Keywords: |
after a getMap Request on a Intergraph WMS this error message appears
<ogc:ServiceExceptionReport>
<ServiceException code="NoApplicableCode">
There was value without key provided in query string.[]
</ServiceException>
</ogc:ServiceExceptionReport>
this is the request that Mapbender has send.
http://62.217.46.150/SG_Wahlbezirk/WMService.aspx?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=STIMMBEZIRK_GEOM2,STIMMBEZIRK_TX&STYLES=,&SRS=EPSG:31466&BBOX=2565610,5661690,2578630,5672190&WIDTH=625&HEIGHT=400&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&
the error occurs because Mapbender substitute an ampersand (&) at the end
of each WMS.
If you delete this ampersant manually the getMap request works.
see:
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/492>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
