[Mapbender-dev] [Mapbender] #502: Querystring preperation doesn't fail nicely when a placeholder is not found
Mapbender mapbender_dev at lists.osgeo.org
Mon Jul 20 12:56:50 EDT 2009
 Reporter:  kmq       |       Owner:  dev
     Type:  defect    |      Status:  new
 Priority:  minor     |   Milestone:  2.6 release
Component:  database  |     Version:  2.6 rc1
 Keywords:            |
 In the lib/database-*.php files in the function db_prep_query we have the
 following lines
 $posa = mb_strpos($qstring, $needle);
 $posb = mb_strlen($needle);
 $qstring = mb_substr($qstring,0,$posa).$tmp.mb_substr($qstring,(    $posa
 + $posb));
 When $needle is not found because, for example, a developer wrote a query
 like this
 UPDATE table SET column_a = $1 WHERE  column_b = $3; --note the missing $2
 then ''mb_strpos()'' stores ''false'' in ''$posa''.
 ''mb_substr()'' interpretes ''$posa'' to mean ''0'' and the poor developer
 ends up with
 value2DATE table SET column_a = value1 WHERE  column_b = $3;
 to fix this I propose we add something like:
 function db_prep_query($qstring, $params, $types){
      $orig_qstring = $qstring;
 and
  if(!$posa) { $new mb_exception("Error while preparing statement in
 ".$_SERVER['SCRIPT_FILENAME']. ": Sql :". $orig_qstring .",Error:
 parameter '$needle' not found ");}
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/502>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
