[Mapbender-dev] Encoding issues
Christoph Baudson
christoph.baudson at wheregroup.com
Wed Mar 11 11:11:50 EDT 2009
Hello,
today I fixed a WMC related bug in Mapbender that occured when the
CHARSET constant is set to "ISO-8859-1".
As Mapbender uses UTF-8 as internal encoding, all data coming in must be
converted to UTF-8, and all outgoing data must be converted back to
CHARSET. Having a single internal encoding is a must, because Mapbender
mixes data from various sources (for example, metadata is gathered from
various capabilities documents). It is also essential, because all the
source code files are in UTF-8!
Currently, this is not done very strict in most classes or modules; we
should improve this. Here's what I found out:
1) in class_administration.php, there is a function parseXml. I changed
the target encoding to UTF-8 (before, it was set to CHARSET), so all
data will be converted to UTF-8, even if the XML is in ISO-8859-1.
2) when interacting with a ISO-8859-1 database, all strings must be
converted as well when before inserting and after selecting data.
3) In PHP, the saveXML method of the DOM library seems to convert all
data to the character set given in the constructor
$this->doc = new DOMDocument("1.0", CHARSET);
There seems to be no need to manually convert data manually!
4) jQuery seems to send all data as UTF-8, so all JSON data coming from
the client seems to be UTF-8 as well, no conversion is necessary.
5) When echoing data to the client, it must be converted back to CHARSET.
For cases (2) and (5) I have added new static functions to
"convertIncomingString" converts a string from CHARSET to UTF-8.
"convertOutgoingString" converts a string from UTF-8 to CHARSET.
We should also think about adding another constant for database
character set. Currently, if you are using ISO-8859-1 HTML output,
Mapbender also assumes you are using an ISO-8859-1 database, and vice versa.
Dealing with both character sets is not a problem, if dealt with
properly. Either we abandon ISO-8859-1, or take some time for proper
testing and bug fixing, as bug fixing is painful.
Thanks,
Christoph
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
