[Mapbender-dev] Source code: character encoding and line breaks
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Mar 13 08:48:33 EDT 2009
The Mapbender source is supposed to be encoded in UTF-8 using unix-style
line breaks (\n).
However, some files are still not UTF-8 and/or have windows-style line
breaks (\r\n).
I recommend to fix this issue before the release of 2.6. As some of you
might still be working on 2.6, I suggest to commit all your changes
until Monday, 1700 UTC+1 (start of IRC meeting). After this, I will
convert all faulty files and will commit them to trunk.
In the future, please make sure to check in only UTF-8 encoded files
with unix-style line breaks. In Aptana, I can set the preferences like this
Window => Preferences => General => Workspace
You can also convert line breaks in Aptana via
File => convert line delimiters to => Unix
I guess the settings are similar or even identical in Eclipse.
Thanks
Christoph
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
