[Mapbender-dev] [Mapbender] #420: Geometry edit in div tag doesn't work
Mapbender mapbender_dev at lists.osgeo.org
Tue Mar 24 15:58:00 EDT 2009
 Reporter:  marc    |       Owner:  dev
     Type:  defect  |      Status:  new
 Priority:  major   |   Milestone:  2.6 release
Component:  wfs     |     Version:  2.6 rc1
 Keywords:          |
 If you change the element element var wfsResultToPopupDiv
 from 0 to 1 in wfs_default.conf
 your spatial search results will displayd in a popup div.
 If want to edit all elements it will be moved to digitize tab.
 But if you want to edit a single element an error appears.
 Here's the firebug output:
 geom is not defined
 [Break on this error] for(handler in
 events[type])if(!parts[1]...ry.isReady)fn.call(document,jQuery);else
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/420>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
