[Mapbender-dev] [Mapbender] #461: element vars of featureInfoTunnel doesn' take an effect...
Mapbender mapbender_dev at lists.osgeo.org
Mon May 4 06:26:26 EDT 2009
 Reporter:  marc            |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  minor           |   Milestone:  2.6 release
Component:  user interface  |     Version:  2.6 rc1
 Keywords:                  |
 ...if you chosse the new popup replacement.
 There are currently 3 element vars defined at this module.
 (featureInfoLayerPopup)
 (featureInfoPopupHeight)
 (featureInfoPopupWidth)
 but they take no effect because they are hard wired in map.js.
 Here's the code from line
        try{
 var p = new mb_popup({
 title:"Feature Info",
 url:path + "?url=" + escape(currentRequest)+"&"+mb_nr,
 width:600,
 height:500,
 top:200,
 left:600
 p.show();
        }catch(e){
 window.open(path + "?url=" + escape(currentRequest)+"&"+mb_nr, "" ,
 "width=300,height=400,scrollbars=yes,resizable=yes");
                                                         else{
        var e =
 new Mb_exception("No featureInfo results.");
                                         cnt_fi++;
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/461>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
