[Mapbender-dev] [Mapbender] #473: undefined default GUI values
Mapbender mapbender_dev at lists.osgeo.org
Mon May 25 08:06:02 EDT 2009
 Reporter:  kmq             |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  trivial         |   Milestone:  2.6 release
Component:  user interface  |     Version:  2.6 rc1
 Keywords:                  |
 When defining a new GUI element in
 source:/trunk/mapbender/http/php/mod_editElements.php, leaving the
 "On/OFF" or "Position" fields empty, causes the the following error
 message when saving:
 "sql error: ERROR: invalid input syntax for integer: "" ROLLBACK
 performed."
 That is an undesirable outcome, as it leaves no clue as to what actually
 went wrong.
 Proposed fix: Give default values to $e_pos and $e_public.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/473>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
