[Mapbender-dev] [Mapbender] #474: Split tree over several vertical
tabs
mapbender_dev at lists.osgeo.org
Wed May 27 02:52:00 EDT 2009
#474: Split tree over several vertical tabs
Reporter: christoph | Owner: dev
Type: feature request | Status: new
Priority: major | Milestone: 2.7 release
Component: treeGDE | Version:
Keywords: |
There is a lot of demand for using the vertical tabs as categories for
WMS.
We should enhance the treefolder module, so that it is able to display
only a branch of the tree configured in the administration interface. Then
you would be able to load the treefolder module in various vertical tabs,
with each instance displaying a seperate branch of the treefolder.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/474>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
